Results 1 to 8 of 8
Thread: 6.2 Military engine
    May 2017
    North Carolina
    Default 6.2 Military engine
    I am buying a 1986 Humvee 6.2L NA diesel engine, I have been told they built these engines stronger for the military.
    Question
    #1 Are the heads are compatable with 6.5L Turbo?
    #2 Can I use the mechanical pump on my 1995 6.5L turbo engine?
    #3 How big can I bore out the 6.2L diesel?
    #4 Can the 6.2L be turbocharged?
    #5 Will the injection lines mate up to the DB4 pump if I have to use these with the 6.2L heads?
    Once again a big Thank you to any who can help me with my dilemma!
    1995 Chevy 2500, 6.5L Diesel mostly stock 234,000 miles. Changed the water pump to HO WP, deleted the vacuum pump and added a mechanical wastegate controller made by me with info from others on the forum.
    Quote Originally Posted by gsimpson View Post
    Question
    The heads will fit
    The mechanical pump will work
    You can turbo the 6.2
    The DB4 IS NOT standard IP used on the 6.2/6.5
    If you mean the DS4 electronic ???
    NO
    The lines are not the same... The DS4 uses a different fitting on the IP end than whats used on the DB2
    The basic engine is the same from MIL to CIVY
    All internal parts are pretty much the same stuff.
    The accessories are different to fit the HMMWV application.
    Hope this helps
    May 2017
    North Carolina
    Thanks Robyn
    So, can I use the 6.5L lines with the 6.2L heads I was told they had different angles where the lines attached to the heads?
    Thanks Robyn
    The HMMWV (and most van) heads are not directly interchangeable with LT heads. The intake bolt angle and injector angles are different. They will fit the block, but the upper LT parts won't bolt on. The MIL and civi short blocks are the same, though.
    The MIL-spec injection pump can be used, but the fuel solenoid will need to be swapped out for a 12V. The DB4 IP was a marine/stationary application pump, and not used in LT or HMMWV applications. They are rare and expensive, but I've not seen but very few uses that actually saw an advantage using them.
    May 2017
    North Carolina
    Default swap
    Will the injectors from the 6.2 work on the 6.5 engine?
    I was told that the engine I bought was a bring back from the "surge", and that they are not in bad shape been thinking about a straight swap but its a mechanical injector so I am guessing I would have to build a linkage and use a regular gas pedal and cable to achieve that.
    How would it affect the computer to do this?
    Sep 2017
    Vernon, Fl
    If you wanted to keep it mechanical you could do that. If I were you I would but a set of head gaskets and swap the 6.5 heads onto the 6.2 if it had different injector angles and just use all of the 6.5td stuff from the shortblock up. Then it would be a direct bolt in deal, plug up and go.
    Not likely. Too many variables. The IP, heads, injectors and lines must all be of the same series, application and generation or they won't fit.
    This is a marketing point (hogwash) to sell surplus engines. It isn't likely they know where they came from. The military doesn't intentionally replace/remove good engines in working equipment.
    Adapting a MFI injection pump to an EFI engine/chassis is a conversion. It's a lot more than just installing a throttle cable.
    The computer won't be happy. You'll have to do a complete conversion to MFI to make the electronics, instrumentation and tranny (if auto) work. A manual tranny is much more simple, but still requires the remainder of the system to be "converted".
    Think of the injection pump as the heart of the engine and the computer as the brain. Then you’re saying you’re going to have the brain control everything but the heart…
    It’s going to be reading all the signals and trying to adjust the fuel accordingly - but won’t be able to because “another brain” will be controlling that (mechanically).
    As DMax says, you’ll have to make everything mechanical or make everything electronic.
