Results 1 to 6 of 6
Thread: Codes 84 and 99
    Feb 2010
    Question Codes 84 and 99
    I have 84 and 99 codes on my 95 k3500. Is this a indication the APP is bad or something else?
    Some times the pedal feels like it has a dead spot in it.
    1995 K3500 Silverado extended cab dually auto trans. Diamond Eye exhaust, KOJO chip, manual boost control, HD cooling, PMD behind bumper, modified fan clutch.
    Jan 2005
    Denville,New Jersey
    Did you swap the PMD yet? Are these the only codes set?
    Feb 2010
    Only 84 and 99 codes, new pmd about a year ago.
    Feb 2010
    Question
    Is there a way to test the accelerator pedal position sensor?
    Quote Originally Posted by 94GMC2500 View Post
    Yes, and your truck's PCM already did. All you can do is check the connections and/or replace the module. The APP has 3 independent/redundant circuits. If one fails (or if all 3 don't agree), it warns you, and the SES and STS (Service Throttle Soon) lamps should be on. If 2 fail, it limps. If 3 fail, it doesn't work.
    Feb 2010
    Thanks for the info!
