Originally Posted by
killerbee
do you have some way of measuring plenum temps? This whole thread, and the other sure has me wanting to go out and by a new set of lawn darts. Are you sure you were talking to a Banks rep? So far, nothing that you refer to banks makes sense to me. Are you referring to IAT? If so, that is measured at the MAF sensor, not the intake, and yes, of course that will change if you mess with MAF orientation (the nuttiest idea yet IMO). But more importantly, is has nothing to do with EGR. Your IAT is the temp of air entering the box, way upstream of any egr interaction.
Lets go back.
If you have the stock tube, and the MAF is in the stock location, NOTHING that you do to modify your intake upstream of the element is going to change your MAF reading. I repeat, nothing.
This whole idea that a free flowing intake will change your MAF reading for a given boost and rpm setting, is TOTAL BS. That is what the idiotic intake manufacturer morons want us to believe, and believe you me, there is no truth to it. "flows more air"? Not a chance.
I'll help clear up MAF tuning in a diesel. If your MAF is down (significantly), whether it be because of a boost malfunction, or MAF sensor degradation, or any other mishap, fuel will be limited in proportion according to a histogram matrix that sees to it. Very simple, not complicated. Oil coating the sensor could be such an event. Oxidation of the hot wire, another.
If you want to check it, just get onto someone with EFILive and log it. You should see 48-58 lb/min airflow (stock MAF location) in 90 degree weather, near 800 ft above sea level, using stock WOT boost settings and 3200 rpm. I will bet you fall into this category.
