Results 1 to 2 of 2
Thread: Concentric slave cylinder question
    Mar 2008
    Default Concentric slave cylinder question
    On my 97, the transmission won't go into forward gears with the clutch fully depressed. I can force it into reverse, and then the truck starts rolling with the pedal floored. I bled the system, and the fluid is clean and clear. I checked with the PO(family) and his recollection is that the slave/bearing was replaced with the clutch(roughly 50K ago), but not the master. Had my helper bottom pedal after bleeding and travel is approximately 1/2 inch by educated eye. I am digging through my shop manual, but so far cant find go/no-go on bearing travel.
    I searched threads here, but all threads concern fork style bearing.
    Any help/info appreciated
    Tom
    97 K3500 w/NV4500-work in progress
    85 M1009A1
    96 C1500, 5.7 w/4L60
    73 K20, 5.7 w/ M435
    When the ball and fork wear out you lose travel. I don't have any specs and its a bear to pull trans to check. The only problems I've had with the master or slave have been total failure. They don't take any preasure moving the line between them.
