Page 13 of 13 FirstFirst ... 3910111213
Results 241 to 245 of 245
  1. #241
    The 14 bolt is a good addition for sure.
    The little 10 bolt is pretty sketchy if you start reefing on things
  2. #242
    Good score Casey.
    I'm thinking about putting Lil Red's rear disc brake conversion articles back online. I used the very same rear axle in Lil Red that you have here. The articles have the drawings for the brackets along with the part numbers for the OE GM brake parts (2003 K1500).
  3. #243
    Good score Casey.
    I would be interested in reading those! I wouldn't mind upgrading to disc brakes in the future.
  4. #244
    The 4 wheel disc is nice.
    Our 2005 Burb K1500 has 4 wheel disc....A panic stop and that rig just squats....
    Some previous owner put 20" wheels with the low profile tires on the thing.....
    I have not been a fan of the ultra low profile tires on the big wheels...Funky looking....
    275/55x20
    Rig handles extremely well....No roll in the corners......
    The 4 x disc is definitely a good thing......
  5. #245
    Last Post: 07-29-2011, 19:57
    Last Post: 11-06-2005, 07:00
  3. Head Count-KD Open House
    Last Post: 06-08-2004, 07:56
