 Originally Posted by
bobbennett33
				I've been using Stanadyne Performance formula in my truck since I bought it a couple of months ago.  I noticed that the bottle says "store above freezing".  I'd  like to keep a bottle of the stuff in the truck, but I wonder if this could be a problem during the winter months?  Anybody know what happens to this stuff when it gets cold?
 Check out Diesel Kleen in the white bottle it is for cold temps,also if you keep a bottle inside the truck you might want to put that bottle in another container.
If you don`t,the inside of cab will smell like the additive,not real pleasant.
I use a old water jug,and I won`t leave it in the cab any longer than I have to.
Standadyne is pretty much the same as Diesel Kleen in the silver jug,not for below freezing.
				2007.5 GMC Sierra 3500 BLACK SRW C.C. 4X4 LMM/Allison,long bed,Loaded,Westach EGT/Boost pass side, Edge Insight CTS EGT driverside, DIY stock airbox mod, aFe proguard 7 OEM airfilter. Back-up sensors + Back-up camera tied into the navagation screen, Redi Lift leveling kit, Cognito UCA's, Pitman Idler arm support, AMP Power steps, Firestone Air bags with controller in cab.
