Greetings!
I have been reading several posts, and I guess I need to know how to tell what I have.
Info:
duramax 6600. 2002. how do I tell if it is a LB7, LLY etc...
Thanks,
Brad
Greetings!
Info:
Thanks,
Brad
2002 will be an LB7. For any of them, you can tell by the 8th digit of the VIN. Yours is a 1.
Thanks much....
Brad
The 2001-2004.5 model year Duramax 6600 is an LB7, and the vehicle will have a number 1 (one) as the eighth digit of the VIN. Injectors and injector fuel return lines are beneath the valve covers.
The 2004.5- 2006.5 model year Duramax 6600 is an LLY, and the vehicle will have a number 2 (number two) as the eighth digit of the VIN. Injectors and injector fuel return lines are outside the valve covers.
The 2006.5-2007 model year Duramax 6600 is an LBZ, and the vehicle will have a letter D as the eighth digit of the VIN. The 2006 model year LLY engines are said to be the same as the LBZ, except for power/torque rating, ECM & programming and emissions certification.
The 2007.5 - 2010 model year Duramax 6600 is an LMM, and the vehicle will have a number 6 (six) as the eighth digit of the VIN. This engine runs with a Diesel Oxidation Catalyst and Diesel Particulate Filter, and requires ULSD (Ultra Low Sulfur Diesel) fuel.
The 2011-2016 model year Duramax 6600 is an LML, and the vehicle will have a number 8 (eight) as the eighth digit of the VIN. LGH (late in this year range as the eighth digit of the VIN), and the vehicle will have a letter L as the eighth digit of the VIN. This engine runs with a Diesel Oxidation Catalyst and Diesel Particulate Filter, and requires both ULSD fuel and Urea.
The 2017 model year Duramax 6600 is an L5P, and the vehicle will have a letter Y (eight) as the eighth digit of the VIN. This engine runs with a Diesel Oxidation Catalyst and Diesel Particulate Filter, and requires both ULSD fuel and Urea.
More info and additional details on all of these engines can be found in one of The Diesel Page's content areas (i.e. see the Duramax 6600 Diesel Page to learn more).
I have a breakdown on my site under Dmax Performance. It covers the 06 LLY/LBZ debacle also along with VIN samples to show how to decode engine and model year.
How about the VIN digit for gear ratio? I'm looking into buying a 2006 Duramax LBZ 51,000 miles (would be my 1st desiel if I get it.) Anything I should know MPG, common problems, etc. I'm going to look at it tomorrow afternoon. I will use it to haul a travel trailer 5 or 6 times a year (Approx 7,000 lbs. now and maybe 10,000 lbs. I maybe in the market for a larger camper) Most of my driving will be around town, I drive about 7,000 miles a year avg. Looking for any advise I can get prior to purchase. Thanks in advance.
P.S. Vin# 1GTHK23D86F147471 What can you tell me?
All of the 2001-2008 2500HD/3500 series Duramax diesel equipped pickup trucks got 3.73 gears. There is no other option. That said, the differential gear ratio is not found in the VIN, but in the RPO (Regular Production Option) code list in your glove box. There, you'll find a GT4 differential code, which is decoded as 3.73 (as well as lots of other 3-digit RPO codes).
If buying from a dealer, have them provide a warranty history for the truck. This'll let you know whether this truck has been a problem for its previous owner.
Good luck,
That applies to previous engines, 6.2L and 6.5L. It could apply to repowers of other vehicles (with a Duramax), as well. If the truck you are looking at is stock, it will have a 3.73. The Duramax trucks do very well towing very heavy with 3.73 gears, and do well on mileage with the same.
Go to your dealership or any GM/Chev dealership, give them your serial number and get a build sheet.
[FONT=Tahoma][SIZE=3][SIZE=4]2007 2500HD SB CC[/SIZE]
76,000 km's
AFE Stage II CAI
4" Turbo back exhaust
Superchip Flashpaq
[/SIZE][/FONT][FONT=Tahoma][SIZE=3][SIZE=2][SIZE=3]
[/SIZE][/SIZE][/SIZE][/FONT]
Is there anything more/less desirable to the LLY equipped '06s than the LBZs? I am looking to update from my '02 LB7 to an '06 or '07. Should I search only for LBZ equipped trucks or is any '06 model approachable? Also, is there a fuel economy poll posted for the LBZ engines? I didn't see one like the one for the LB7s. Very interesting info!
In my opinion, the 06 trucks are the same and retaining the LLY monicker is one of the stupidest things that GM could do. It just creates confusion. The only real difference is the ECM programming and while the HP rating remained at 310HP, the real world showed it more like 340HP or slightly above 50% of the difference between teh true LLY and the LBZ. When properly tuned they all run the same so no loss.
