Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Fuel Economy Update for the 1993 Diesel Conversion Suburban
  1. #21
    Sep 2006
    Quote Originally Posted by john8662 View Post
    My daily driver is my 82 C10 Shortwide 6.2L stock (except non-egr now).
    It's a 2.73 geard truck, but with 26" tall tires because it's lowered 6".
    I run 80MPH down the highway routinely and it still returns 27mpg.
    J
    I did some calculations on RPM vs speed on your truck assuming you have 2.73 gears, 26" tires and 700r4 transmission.
    mph vs. RPM
    55 - 1358
    65 - 1605
    70 - 1729
    80 - 1976
    Then I calculated the RPM's on my 1982 Suburban with 3.08 gears, 30" tires and 700r4 transmission
    55 - 1328
    65 - 1570
    70 - 1690
    80 - 1932
    It appears that your RPM's are very similar to mine. However, mine does not get as good fuel economy as yours at 80 mph. The lower stance is probably responsible for this. Anyways, it's good to know that lowering these trucks really helps with fuel economy at highway speeds. That said, I may end up dropping my 99 Tahoe that I intend to repower.
  2. #22
    Jun 2010
    Southern Delaware
    Default Oops.. Mathematical error!
    I forgot to account for the 1.5% error that my speedometer has. The correct average fuel economy is a bit lower, at 24.596 MPG. According to my GPS, I am going 54.2MPH when I am reading 55 MPH on the Speedo. That checks out because I am also going 59.1 MPH when I am reading 60 MPH.
    1993 Suburban 2wd 6.2L Diesel Conversion "Andromeda":
    3.73:1 gears, THM 700-R4 transmission, and
    J-code 6.2L diesel from a 1984 C2500 Suburban
    1996 2wd to 4wd converted Ford F-150 300ci Inline 6 "The Argo" 336,000 miles and climbing
    1992 Caprice Wagon 5.0L V8 "Enterprise-D"
    "Ah ha ha ha! I swear! Tractors is so dumb!" - Mater
    "The Argo? That ridiculous pile of scrap metal!"
  3. #23
    Jun 2010
    Southern Delaware
    Quote Originally Posted by Edahall View Post
    mph vs. RPM
    55 - 1358
    65 - 1605
    70 - 1729
    80 - 1976
    55 - 1328
    65 - 1570
    70 - 1690
    80 - 1932
    Does your Suburban have a roof rack? That will put allot of drag on it.
  4. #24
    Sep 2006
    Quote Originally Posted by argo View Post
    It has no roof rack on it. It's just a big old boxy vehicle with the aerodynamics of a piece of plywood held upright.
  5. #25
    Lubbock TX, USA
    Edahall,
    Seems to help. I got the truck that way (lowered) so it's been an experiment. It seems to get around the same fuel economy at 70 as it does 80. I don't use the A/C because it doesn't work, so I know that helps a bunch.
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
