Just took our truck into our Dealer for warranty. I was underneath looking at the airbag install and noticed the telltale ATF sling on the underside of the trans hump right over the rear of the transfer case at the driveshaft. I wiped it off and checked the transfer case level, it was only down about 1/2 inch below the fill plug. So no harm there. We had just returned from a round trip of about 900 miles towing. The dealer said he had seen a few of the seals fail on everything from 1/2 tons to 1 tons, even though they are different seals.
The tech was a young guy, I think he is just starting his career. He was just getting aquainted with the D/Max trucks. He seamed very capable and eager to be on top of them.
He was going to change the fluid in the trans case and replace it with the all-track fluid. I said that I was under the impression that Dex III or the new VI was the prefered fluid. The older tech thought that the all-trac was what was being used for replacement also. They didn't have a problem with just topping it off with Dex VI, is it V or VI? Anyway what is the correct fluid for the case? Also they had an 06 LBZ getting an EGR valve replaced. The senoir tech said that he had done a few of them recently. This is a small dealer with only two techs, but they sell a lot of vehicles. They were great about getting me in the same day while I waited. The techs seemed to be very capable, but I'm sure they get pretty busy, since there are just two of them. The dealer is Bogley Chevrolet in Thurmont, Md. They also just sold the 08 3500 LMM I posted about a week or so ago. They already had another one on the lot to replace it.
