Page 9 of 9 FirstFirst ... 56789
Results 161 to 169 of 169
Thread: LBZ Fuel Mileage
  1. #161
    Feb 2009
    ZEPHYRHILLS, FL
    Just got done tuning an 06 LLY/LBZ, and he went from getting 18-19 running 65 with his bullydog triple dog to 21.5 now doing the same exact trip except now with an EFILIVE tune I put in it for him. I believe he said stock he was getting about 17-18. Stock tuning in teh LBZ isn't the best for milage IMHO, theres no reason to be holding 5-6 pounds of boost while running 55 with no trailer on a flat road. It does make for a responsive truck, but is hurting the milage.
    1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, 3.42 gears, 261 T-case
    Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4 and a PI ML converter
    DIAMONDEYE 4" exhaust with a CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump and pump rub kit.
  2. #162
    Apr 2011
    klamath Falls, Oregon
    Quote Originally Posted by THEFERMANATOR View Post
    Sure would like to hear more about that tune. That is an impressive mileage gain for cruising.
  3. #163
    My observations are have been that LBZ and LMM powered trucks get about 15% -20% less MPG than the LB7s when driven unloaded.
    When towing, the LMMs do a little better than the LBZs, and only about 5% - 10% less than their LB7 predecessors, with much more stock power and a much greater ability to diffuse heat from the cooling stack. The LMM is a major improvement over the LB7 in the power department for just a little more fuel consumption, and still a measureable improvement over the LBZ family in both MPG and heat management.
    After 11 years of production, team Duramax continues to improve...
  4. #164
    Feb 2009
    ZEPHYRHILLS, FL
    Quote Originally Posted by gimpyhauler View Post
    This was with an EFILIVE tune that I got from another forum. I tweakd it slightly to smooth it out, but it is a pretty basic tune. About 2-4 degrees more timing in the cruise area, and the boost was lowered about 3-4 pounds at cruise as well as opened up the turbo vanes. It made it a little sluggish to respond to throttle changes, but it was a good trade-off for the milage gains. Plus it was a DSP5 tune so all he had to do was flip the switch on the dash and it came right back to life.
    With a basic tune the LBZ and LMM can both get almost teh same milage as the LB7's, and like you pointed out they are so much more refined and powerful. After tuning and driving one, I kick myself for swapping in a LB7 into my BURB, the LBZ would have been worth the extra effort in the end.
  5. #165
    Jan 2012
    wausau wi
    Cool
    hi i have a 2006 with 94000 mi with the lbz and if i keep it uner 1700 rpm on the hwy i get 23.2 mpg's
    2006 Chevy 2500 with Edge juice with attitude programer, and 5 inch stacks.
  6. #166
    May 2007
    Dixon, CA
    Default Mileage change with Banks Economy tune
    For reasons unrelated to mileage, I am going to be using a Banks tuner in my FMC motorhome conversion to the LBZ (there is a thread in the Conversion forum). The tuner has an "economy" setting.
    Does anyone have any experience with using this setting in a Banks tuner. Any thoughts on a percentage improvement in mileage that would be reasonable to expect vs the stock setting. I will be basically running "loaded" all of the time as the coach weighs about 14,500 lbs.
    Stephen H.
    BigRabbitMan
    1976 FMC Motor Coach #1046
    Formerly 440, now LBZ
    Rear engined w/4 wheel independent suspension.
    Tow car: 1987 Subaru Brat 4x4
    http://www.fmcowners.com/mbbs22/phot...asp?albumid=77
  7. #167
    Nov 2003
    Davenport Florida
    I am wanting to get the best MPG out of my new to me 2007 2500 CC LBZ with 248k on the clock. I drive MOSTLY unloaded, in Florida, and im only seeing 16 -17 mpg. The tires on the truck are very new 285/75/16 , and I do correct for larger tire size in mileage calculations, and use GPS to compare. Im wondering how much the larger tires effect the fuel mileage, and what difference I would see if I went back to the 245/75/16 size that came on the truck. From what I have found, my tires are 2" taller, so it raises the truck 1 inch. I have always heard lower truck = better mileage, but I dont know how much 1 inch will change things. Any experience / suggestions would be greatly appreciated.
    I am also planning to install a DSP5 and EFI tunes at some point. I want the economy tune, and the ability to switch to more power when I need it. I think this would give the best results for better mileage, over messing with the tires.
    email rfkjr@juno.com
    07 2500HD C/C LBZ 248k
  8. #168
    Dec 2005
    Klamath falls/keno Oregon
    21-23 on a stock engine, 420,000 miles on the clock. That’s Highway mileage..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
  9. #169
    Just went from Knoxville TN to Fredericksburg VA round trip 2006 Sierra 3500 Dooley. Hand calculated 15 1/2 up 16 1/2 back. Just a couple suit cases in the back. Dash computer had me at 14 1/2.
