OK, so if I have confirmed it runs with the engine running, it should be running all the time with the engine running. At least I can rule that out. When I activate the priming circuit (pigtail just behind the fuse box) I can watch fuel come out of the center tube in the FFM There doesn't seem to be any bubbles at all, but it just flows very slowly. It does not fill as fast as the engine uses it. I have ordered the in-tank sock, so hopefully that is where the issue is.
Jeffrey Todd
_ _ _ _ ___ _ _ _ _
