Page 5 of 12 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 226
Thread: P0087 fuel rail pressure low limp under high loads
  1. #81
    Any chance of making this programming available via the Diablosport/Predator handheld as a custom tune?
    If no - is there any way to reflash the stock ECM with this fix and a mild tow/economy bump.
    Reason for asking is this truck is probably going down the road this fall, as part my my relocation to Seattle. I'd like to sell it with a solution for the P00087, that doesn't require or assume much knowledge of the end buyer - i.e. whomever gets it at the auto auction after its traded in.
  2. #82
    There's no way that I'd be working with any other "generic" hardware. This will be something that I wil incorporate into my Kennedy Custom programming. The next issue though is will the bump in power make the code set again. Still a lot of questions, but it looks like we're making progress...
  3. #83
    Test subject stopped in today and I verified which tune it was that worked. Planning to do lift pumps soon, possibly next week. I also have him cleaning fuel cooler. It looks pretty grungy at a glance.
  4. #84
    Default Update
    I recently did a performance tune for LMM and added the same correction. Customer made trip and tells me that he easily would have tripped 12 or more times on this type of run. He thought that he was free and clear, but managed to trip it once just out of the blue. Considering the added demand/load of the tuning this isn't bad. We are taking a wait and see approach and will consider more tweaking if the issue persists.
  5. #85
    Unless that guy is hauling in the southwest, my guess is he will have more issues next summer when higher temps return. Ambient temps which contribute to high fuel temps are a big part of this issue.
    I am finishing up a 3000 mile trip today, with a heavy wide boat and through terrain that would have tripped the P00087 many times last summer. So far only two codes set, and that was running hard uphill with a low tank of fuel. The only difference? About 30-40 degrees less ambient fall temps.
    This issue is best solved via programming tweaks, but it is clearly a combination of all that has been discussed, including:
    • High mile or high fuel volume injectors (i.e. always towing)
    • Heavy loaded towing, usually compounded by hills
    • High fuel temps, caused by excessive return rates, low fuel level in tank, poor fuel cooling or flow, etc.
    If I'm still hauling boats next summer I will buy your finished product, if it can be warranted to solve yproblem. However, my goal is to be in Seattle driving a 2012 ZL1 Camaro by then, although I may be driving my daughters Jetta if I can't find anyone to buy my biz...we'll see which happens first!
    Mark @ www.MREBoatTransport.com
  6. #86
    This trip was made during conditions that would have normally caused the limp numerous times. I'm a bit late in reporting.
    Customer is well aware that he's likely delaying the inevitable and that there are NO GUARANTEES and I make this clear in my Tech Tip, but for now if it helps minimize the instances plus increasing the capabilities if in limp mode it's a win-win for most.
    Again no guarantees, BUT a willingness to adjust and tweak to work around the issue as needed.
  7. #87
    Oct 2007
    I have been curious if diesel fuel is formulated for use in a high pressure application like the Dmax. Most of the fuel the pump picks up is by-passed back to the tank so fuel is constantly recirculating and besides picking up heat from the engine it also adds heat from being under pressure. I wonder if a fan located to blow on the fuel heat exchanger would help. Also the fuel constantly be re-circulated and the ultra low sulphur content of the fuel might be reducing lubricating properties of the fuel to the point that it harms the injectors.
  8. #88
    Nov 2012
    Ridgway, CO
    Default p0087 Issue
    I've been a victim of this same issue now for a month. We replaced all of the stock fuel lines, installed an airdog and completely bypassed the stock filter housing, and I still get this same message when I lay on the throttle or when towing heavy loads. I have 2007.5. Could it be the FPRV?
  9. #89
    How many miles on your injectors? What other filtration are you using? Lift pump?
    Potentially anything that could cause the system to not deliver actual fuel rail pressures as commanded by the ECM can be to blame. I have personally never seen unloaded/high acceleration set this code.
    In my cases its always towing heavy in the hills with heat as an exaggerating factor - i.e. HOT fuel.
  10. #90
    Update: Interesting observation today while running same route from Grasonville, MD through mountains of MD, WV, PA...the route that tripped the P00087 countless times in July with a SeaRay 310 (12000#) in tow at 85F outside temps.
    Today was a Chaparral 350l, tipping the scales closer to 15K#, but the outside temps ranged from 14f to an icy 9f.
    You guessed it...no matter how hard I drove the truck (extended 4th gear, 3000rpm charges up 8% grades to maintain 55mph, passing semis with their flashers on one after another) I never set the code all day.
    So...it may be a worn injector situation that causes the high return rates, that heats up fuel, that contributes to low rail pressures...BUT...the biggest cause is
    HOT FUEL. (period)
    Somebody make a bigger undercarriage mounted fuel cooler with fan assist and I think you'd narrow the window considerably, if not eliminate it entirely, throughout the lifespan of the injectors. I have 155K on my originals and they are running as strong as day one. Not touching a thing, certainly not for a pesky code where I can push a button and 'fix' the programming error. Its certainly not worth installing new injectors to fix, at least not in my case which is towing heavy on hot days in the hills.
    I know...how about we programmatically correct this bug in the ECM?
  11. #91
    I still have guys calling me with this issue in the winter months here. Odd, but some are still having issues. I've sent out some revised tuning and made sure that they understood that things may change when it warms up so we'd readjust then. Only time (and hot weather) will tell.
    The big fan fuel cooler idea may help, but you can't get below ambient in the tank and I think on a hot summer day she'll just heat right back up again as the temps are coming from the journey across teh valley to the CP3, the pressurization within the CP3 and probably to an even greater extent from the release/backflow at the injector.
  12. #92
    Jan 2013
    VA
    Im having the same problem on a 06. I put 8 new gm injectors in and still having the same problem. It only does it at wot and when its warm. Pump at idle you can ramp it up to 24000 psi and hold it all day. when it warms up it will command 26000 and drop to 12000
  13. #93
    Jul 2012
    All over U.S. (traveling)
    Default In the Shop in TX
    Today we brought our truck to a guy that specializes in fuel line issues here in Austin, TX. We finally bought a device to reset the code back in Sept so we haven't been wasting time waiting for limp mode to clear on its own. That seemed like major progress at the time.
    However, the whole issue seems to be getting worse and becoming more of a pain to reset while driving, especially in traffic. We feel that towing 12a + ton toy hauler and dealing with these limp mode issues is going to become unsafe at some point. The code is now setting at lower temps than before (low 60s) and while going up minor but long inclines. In a nutshell the issue seems to be getting worse.
    Once we get our official diagnosis I will post back here.
  14. #94
    Quote Originally Posted by Maxdout1 View Post
    I can only speculate that you may benefit from some tweaking in the tuning. This is ASSUMING thatyou are not running a plastic bodied fuel filter and have no excessive restriction.
    I'd probably start by lift pump supply pressure first.
  15. #95
    Dec 2000
    Hawaii/Arizona
    Default Hot Fuel
    I often tow 24k lbs in the Arizona mountains at 115f and my 185k mile LBZ truck has never set P0087 code or gone into limp mode. I have a 100 gallon aux fuel tank and a gravity/check ball feed into the 34 gallon primary fuel tank. This system keeps the 34 gallon truck tank full at all times. I think the full tank of fuel absorbs a lot of the heat from the hot return line fuel which helps keep the entire fuel system cool. Additionally, I pressure wash the fuel cooler under the truck bed about every 30-60 days.
    I would suggest to anyone setting the P0087 code to pressure wash your fuel cooler and keep as much fuel as possible in your fuel tank when towing. It won't cost anything and it seems to be working for on my truck. I could just be lucky and my truck could start acting up tomorrow.
    Good Luck
    John
    *2007 Pontiac Solstice.
  16. #96
    This supports my theory that its about HOT fuel, as much or more than return rates. That should have been solved with new sprays. How many miles on the truck when it first occurred?
  17. #97
    Quote Originally Posted by CoyleJR View Post
    Good Luck
    John
    x2 on the HOT fuel theory. I assume these are your original factory sprays, John?
  18. #98
    Dec 2000
    Hawaii/Arizona
    Default Injectors
    Mark,
    Yes my truck is running the original (from the factory) injectors. The only things that are not original on the truck are the drive shaft carrier bearing, one glow plug #8, and tires and brakes. It is the best truck I have ever owned. Good luck when you relocate.
    John
  19. #99
    Aug 2012
    Michigan
    Quote Originally Posted by Demilee View Post
    Please let us know any updates you may have! We are here at your convenience.
    Brandon
    GM Customer Service
    For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html.
  20. #100
    Jul 2012
    First of all, I'd like to thank Mr. Rinker for suggesting we purchase a scanner to clear our codes while driving. We were so sick of waiting on the side of the road for the limp mode to clear on it's own. We finally got one last summer. BTW the code only did clear on it's own as trans. temps got lower. Maybe that can info can help someone out? Maybe that has to do with the FUEL temps?!?!?!
    Anyway, I'm reporting back regarding the service we had done in Austin for the P0087 codes we are getting... We were hopeful that the guy at the shop was correct when he thought that it was a valve and seal (used to diagnose fuel pressures?). It ran about $90 to replace that, he noticed it was broken just after opening the hood of the truck. He said if that didn't work he recommended "Kill'Em". (We have not tried that since we were going to be towing in a few days and wanted to see if the valve replacement worked.) He tested the fuel injectors and said they all looked fine. (Even though we were told at a Chevy dealership in Pensacola, FL in 2011 that we needed 4 replaced!)
    So, our trip from Austin, TX to Tucson, AZ started out great! We thought that we had found our FRP Savior. Nope... We left early in the AM, when the temps were low. My story is quite consistant with Mr. Rinker's you see, high outdoor temps and under load with hills pops P0087. We ended up stopping to take a nap and let the temps cool outside. The cool desert night is our friend with this FRP issue.
    Interestingly, we got a code of p2002 a two times within our 1.5 days of travel to Tucson. Also, got a p2563 code as well. I understand these are both emissions codes, likely unrelated? If no, maybe that is another clue?
    With the 85k miles we have put on this truck driving around the U.S. for the past one and a half years, UNDER LOAD half of the time, I've also come to believe this is a FUEL TEMP issue. This supports Rinker's theory and has been mine for awhile as well. I do 95% of the driving when we're towing. It's like I know the truck personally now, and I know when it's going to pull the dreaded p0087 code.
    Since I am a "dumb" girl at least I had enough sense to ask the last mechanic about where the dang fuel cooler was so I can try to clean that next. I'd rather not pull out the bottle of "Kill'Em" we bought. That stuff is lethal, I can't believe you can even buy it over the counter. (I'm a bit of a klutz and I'm afraid it will get on me.)
    I'll be checking back again soon after some more troubleshooting. I welcome any feedback. Cheers!
    -Demi
    2008 Silverado - 3500 HD DRW (189k miles - symptoms since ~115k - purchased at 105k)
    *We've had the GM bulletin PIP4526 collapsing fuel line issue addressed already.
    *Our fifth-wheel is 11-12.5 tons. (arrived 21k from the manuf.)
