Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: 6.2/6.5 Diesel Conversions - The High Points
  1. #21
    Nov 2012
    USA OK Ponca City
    Quote Originally Posted by stuntdoublejoe View Post
    I now have the VRV/Vac Pump, so now my question is how do I change up the governor and shift points?
    Hello there ... New on here ... Which trans are you going with .. If you use the TH350 you can get a variable modulator valve that you just make slight adjustments to until you get it shifting where you want it ... I am not sure with the TH400 .. but the 700R4 is the easiest of all.. you simply pull the pan ( you would want to install a new filter kit anyway ) and while you have it dwn you pull out the electric lockup actuator and put a 5/16 rubber ball bearing on it and place it back in .. this makes the 700 work completely automatic .... you then just have to have the shift valve control cable hooked up and set propely .. ( although there are different valves available for gas and diesels ) this cable not only controls the shift range but also controls the pressure applied to the clutch packs so it is vital that it is hooked up on a 700R4 ... I made this mistake once with my '66 chevelle and burned up my tranny ...
  2. #22
    Feb 2013
    AZ
    Do you know of any low mile 4x4 donors. Prefur a 6.5
    Thanks!
  3. #23
    Mar 2014
    VA
    [LIST=1][*]The GM 6.2L and 6.5L diesel engines share the very same bellhousing configuration and bolt pattern with all Chevy and GMC V-8 gasoline engines.[*]The GM 6.2L and 6.5L diesel engines share the very same motor mount configuration with all Chevy and GMC V-8 gasoline engines.
    Correct me if I'm wrong, but 6.2s/6.5s don't share the very same bellhousing configuration as all GM/GMC v-8 gas engines. According to wiki's list of GM bellhousing bolt patterns anyhow http://en.wikipedia.org/wiki/List_of...using_patterns.
    EX- The GM 5.3L LS4 V8 uses the GM metric bellhousing pattern.
    I'm a newbie on here and am by no means an expert. Hope this is helpful.
  4. #24
    Quote Originally Posted by AdrenalineJunkie View Post
    Referring to the 6.2/6.5 GM Diesel engines, they are the same as the gas V8 engines of the same light truck tooling series (GMT-xxx). Also note this does not include the BOP patterns. The (current) LS4 was not offered in a light truck, and was not in production at any time the 6.2/6.5 Diesel engines were an OEM option. It's a muscle car engine.
  5. #25
    The transmission bolt pattern statement was 100% accurate at the time it was written about 15 years ago. If Chevy/GMC changed its bolt pattern for some newer engines, that would be good to know, and I appreciate your input.
    For a little historical perspective: GM established the Chevy transmission bolt pattern we're talking about here with the introduction of the 1955 model year 265 C.I. smallblock gas V-8 used in its cars and light trucks. That bolt pattern was carried forward into GM's 1960-90s era 396/427/454 C.I. and 8.1L bigblock gas engines. That bolt pattern was carried forward into (as Greg mentioned) into all Chevy/GMC full size gas and diesel powered light trucks through the entirety of the 6.2L/6.5L production. And finally, that is the same bolt pattern currently in use by the Duramax 6600.
    Jun 2014
    Cullman al
    If you read the article closer you will see that the LS4 was adapted to put in a front wheel drive vehicle, Most front wheel drive GM's use the metric pattern. All the other v8's still retain the original Chevy bolt pattern.
  7. #27
    Feb 2014
    USA CA
    The 5.3L is not a factory muscle car engine, it's the half ton PU and Tahoe platform engine. However, it is swapped into muscle cars because it can handle a lot of boost on the stock bottom end (iron block version). Same goes for LQ9 6.0L engine.
  8. #28
    Quote Originally Posted by Gradient View Post
    Not all 5.3L GM gassers are equal. The LS4 was never a light truck engine, and shouldn't be confused with other historical "LS" series engines. They were OEM in late model "muscle cars" brands, such as Monte Carlo and Grand Prix (in transverse configuration), among others. The LM4 is the aluminum block light truck engine, the LM7 is cast iron. There are numerous "5.3L" engine option configurations from 1999 to present model years. There is no correlation between any of them, and late model 6.0/6.2L gasser engines. Different animals, with very different applications and control systems. The 6.0L LQ4/9 light truck engines are unique unto themselves, not to be confused with the "LS" (and other) series 6.0L's.
  9. #29
    The following link contain a number of member vehicles that, some at least, are focused on 6.2L/6.5L diesel conversions. Some are from the early years of The Diesel Page, while others are somewhat newer. All are interesting. Have a look.
    https://www.thedieselpage.com/readers/readers.htm
  10. #30
    This thread is 14 years old so I'm not sure if it will be replied to or not but here goes. Truck I just recently picked up is a 94' K2500 14 bolt cooperate rear with 4:10 gear set. It has an NV4500 five speed and currently houses a 454 7.4 TBI gas sucker. I'm researching the easiest means of swapping to a diesel engine, not sure if that would be a 6.5 or if possible to go Duramax. If I'm understanding the previous posts it sounds like a 6.5 would be a direct bolt up to the factory motor mounts and also the NV45 but will require a different flywheels and clutch kit. Furthermore it also sounds like the Duramax would also bolt to the NV45 and respectively also require a flywheel and clutch kit as well as TDP motor mounts. Somewhere in the 6.2/6.5 forums I read that the 6.5 weighs a respectable 700 lbs which I believe is also the same weight as the 7.4 liter BBC. taking all of this into account it sounds like swapping in a 6.5 would be the most painless swap while retaining the NV45 and keep the weight relatively the same as it is now? I understand that there are known issues with the 6.5 but I've also read about issues with LB7 so what are the pro's and con's between these two motors? This truck was purchased to be a camping vehicle when I retire which if all goes well will be in 10-12 years but I plan on using it leading up to retirement to carry my 2400 lb camper. any thoughts appreciated.
  11. #31
    a 6.5 with mechanical pump would probably be the easy way to go. Considering the weight of your camper should do fine. If your going to tow/haul heavy Duramax for sure.
    My first diesel was a 94 GMC K2500 6.5/5 speed. I bought a 36 ft fifth wheel and i pulled it but it was a chore. When I retired I picked up an 06 GMC D/A and it pulled that trailer a lot better. When we left out after living in the fifth wheel for 15 years it was loaded heavy. Scaled it at 24500 lbs. Donner Pass was first workout. Then across Utah, North Rim, and Santa Fe. Made it to East Tennessee where we are now.
    Made a couple trips to Northern Virginia and now the fifth wheel is gone.
    Lighter towing 6.5 but heavy go the Duramax
  12. #32
    Seat of the pants performance of a nicely built 6.5TD would approximate a healthy stock gas TBI 7.4L 454, whether driving unloaded or towing. A performance built 6.5TD could improve on that. Since the truck you have now is not a 6.5, you could/should do as A5150 said, and go the mechanical fuel injection route. That could get you close to stock performance for the first gen LB7 Duramax, which is great...
    Installing a Duramax is an option, but whether this might be the "best" option would depend on your KSA's... (knowledge, skills and abilities). We've got the conversion process pretty well figured out, but still, a lot depends on the one doing the conversion. Reading through the Duramax conversion threads here should give you some idea about the process - and we're here to help. Jim
