Results 1 to 6 of 6
Thread: Duramax Conversion Motor Mounts
    Arrow Duramax Conversion Motor Mounts
    Quality Mounts To Help Get Your Project Started
    Aside from having the information you need to complete a Duramax conversion, having a ready-made and quality set of conversion mounts will go a long way to help get your project underway. GM changed the motor mount configuration beginning with the 1999-2007 body style trucks - producing an asymmetrical positioning on the engine, meaning one mount is further ahead of the other side. Not only are the Duramax factory motor mounts positioned asymmetrically on the engine, but they are also very different when compared to earlier GM full-size trucks and SUVs. The professionally produced generation II mounts shown here solve that problem, making it possible to install a new Duramax 6600 diesel engine into an early 1980s to late 1990s GM full-size.
    Update: 2/2025 - A question came up recently about whether the swap mounts we offer will fit the newest version of Duramax 6600 - the L5P. As it turns out, the LB7, LLY, LBZ, LML and LMM (2001 up to the 2016 model year engines - essentially all but the L5P which first appeared in the 2017 model year GM trucks) utilize the same engine mounting dimensions and bolt patterns. The L5P block casting, on the other hand, was largely redesigned to include new engine mount locations/bolt patterns on the block. We're working on offering an updated mount design for the L5P/GMT-400 swap (for the 1988-1998 body style). Should have the mounts available later this spring.
    In addition, we've seen that, through the years, GM Powertrain added more and more emissions-related components to the top of the engine. The L5P is the pinnacle of that trend. To maintain adequate hood clearance in a GMT-400 body style truck swap, a cowl induction hood and/or a body lift will be necessary. I'll have more information on all this as soon as I get my hands on an L5P. In the meantime...
    Click HERE to read more about these mounts and to place an order.
    Jul 2017
    Carlsbad, New Mexico
    Aside from having the information you need to complete a Duramax conversion, having a ready-made and quality set of conversion mounts will go a long way to help get your project underway. GM changed the motor mount configuration beginning with the 1999-2007 body style trucks - producing an asymmetrical positioning on the engine, meaning one mount is further ahead of the other side. Not only are the Duramax factory motor mounts positioned asymmetrically on the engine, but they are also very different when compared to earlier GM full-size trucks and SUVs. The professionally produced generation II mounts shown here solve that problem, making it possible to install a new Duramax 6600 diesel engine in an early 1980s to late 1990s GM full-size.
    Please click the above link to read more about these mounts and to place an order.
    Wish I would've been able to find these last month before I had some built for my 1994 k1500-lb7
    -94 K1500 lb7 swap
    -06 Cl55 AMG Mercedes Benz @ 12.3 seconds
    -04 E55 AMG Mercedes Benz
    -08 f150
    Sep 2003
    Feeniks, Aridzona
    Now we just need stand-alone ECU's so we don't have to deal with the dashboard wiring.
    Ft. Wayne, In.
    Agreed Jeep,
    Jim, Is there anyone out there that has a cure for that? I'm guessing there is and I've just not seen it yet. After so many years there should be. Lots of folks out there using them by now for other projects.
    D
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '97 2 Dr Tahoe, Intercooled,
    Kennedy ECM, 4" Exhaust
    '02 GMC
    Agreed Jeep,
    D
    PPE (www.ppediesel.com) offers a standalone harness and computer. Spensive though... I also think Banks is offering a standalone system - marine app, but possibly adaptable to on-road.
    I talk more about electrical harnesses and offer some suggestions HERE.
    Ft. Wayne, In.
    Thanks Jim,
    I figured there would be something out there by now.
    d
    Dave, N9LOV
    Member #242
    Dave's Diesels:
    '02 GMC
