Results 1 to 2 of 2
Thread: US to GB
    Default US to GB
    Hi guys, I have a Silverado 2500HD 2002 purchased new in 2002. It has full towing package, and it is a Canadian vehicle , which has the Amber Indicators.
    Not like US models that uses the stop lights for Indicators.
    It is a 7 spade tow plug on rear, and I have just purchased a Camper (British) with GB 7 round pin connector. Is there an adapter to plug in both to alter the lights ?,
    `Dek
    Quote Originally Posted by Dek Hawkins View Post
    `Dek
    I am not familiar with the GB 7 pin connector, but the US 7 pin connector already has a built-in converter to change the separate amber turn signals into the combination red turn/stop lights.
    The US 7 pin connector has wires for the following:
    LH stop/turn
    RH stop/turn
    Clearance/tail/running
    Electric brakes
    12V battery charge
    Backup/reverse
    Ground
    This might be the adapter you need:
    7 blade to 7 round adapter
    You could also replace the male plug on the camper with a 7 blade connector.
