Thread: 95 6.5 diesel and PMD
    Jul 2023
    Olds, alberta, canada
    Default 95 6.5 diesel and PMD
    Hi; my first post. I have a 95 GMC , 300,000 k, with the 6.5 diesel that seems to have recurring pmd issues. One of the replacement advertisers claims a weak injection pump will burn out the pmd, I can't find any supporting references and am looking for input. Thanks
    Jul 2023
    Welcome to The Diesel Page!
    How is your PMD mounted? What PMD brand are you using?
    I only use the truck occasionally. After the initial failure about 10 years ago, I relocated one , can't even recall the source, to the front bumper, which worked well Until 2 years ago. I got one off Amazon, a knock off, which worked well for about 3 months, strange part being when I connected it directly it would still operate. Since that time I've been driving the truck with the PMD, on a heat sink, lying on the intake manifold. Quit again the other day. If I'm going to replace it again, I'd like a recommendation for a dependable brand as well. thanks.
    I recommend the Stanadyne module that is gray in color. I really don't like Stanadyne, because they are largely responsible for the electronic failure reputation the 1994 and newer 6.5 endured, but they did eventually develop a much improved module... even if it did take them till 2008 to do it.
    Correct mounting and cooling is vital to long-term success. Can't be sloppy about it or use cheap parts. These modules generate considerable heat while in use.
  1. Turbo Diesel Interceptor PMD/FSD starts death throws
    By 16gaSxS in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 05-23-2014, 11:49
  2. New PMD
    By Jurek in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-23-2013, 11:56
  3. Pmd
    By ScottB in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 12-27-2012, 15:07
  4. HEATH DIESEL pmd isolator
    By weigellj in forum TDP Classified ad forum
    Last Post: 01-09-2012, 13:15
  5. PMD
    By woodrous in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-02-2003, 03:07
