Results 1 to 7 of 7
Thread: egr heater pipe part
    Dec 2005
    Klamath falls/keno Oregon
    Default egr heater pipe part
    mine got broken during the turbo replacement, its the glass-reinforced plastic part on both sides of the engine,
    that go into the intake...When I look it up it shows a part for the 04-06 but it aint mine...
    garcia.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    429,000 miles and counting..
    2006 was a transition year for the powertrain. It got the LBZ and 6 speed, but kept the LLY code and power programming. My son has a 2007 GMC "Classic" 1/2 ton, which is the same as the 2006, mostly, sometimes. 2007 was a transition year for the body. Transition years, with GM, generally start in January of a calendar year, in the middle of a model year. For the later Silverado/Sierra models (they were previously only trim level names), this was M/Y's 88, 98, 07, and a couple more since. Some models, weight capacities, and powertrains, get hung up in between, and often get some updates but not others, or get pushed off for years (there were no GMT 800 in 1999 above 8600 GVW, no 3500, but the 3500HD OBS was still made, until 2001, for example). Getting the right parts for these models can be a chore. Sometimes, we have to match it to a 2007 Classic Chevy, or the 2007 GMC NBS, for my son's truck. Your powertrain is more like the LBZ in most respects, so if parts don't match, look for the LBZ part, late 2006 or 2007 "Classic" for a match. Don't even trust a VIN match. Look at the part. The parts stores are getting better, but we still have issues.
    Dec 2005
    the cartoon showing the part doesn't match what mine looks like.. I JB welded it together, if it holds, Ill be satisfied..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Thank God for duct tape, bailing wire, JB Weld and WD 40
    Did you look up the part for a 2007? What Greg was saying above is sometimes you have to look at the next model year.... If the 04-06 doesn't match, then try looking for the 2007 and later version.
    Cartoons never look exactly like the real thing!
    Dec 2005
    JB weld has held..Im good.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. heater hose assembly part number?
    By bx8lugger in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-08-2012, 18:44
  2. Anyone use SSdiesel block heater cord or lower radiator block heater
    By aquaman0001 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-12-2011, 14:10
  3. Part number for D.S. heated butt seat heater
    By Rick Henderson in forum 2500HD/3500 Accessories
    Last Post: 03-27-2007, 12:34
  4. X-over pipe
    By DA BIG ONE in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-26-2006, 04:31
  5. Oil pan heater/pre-lubers/espar/block heater/idling
    By imported_ in forum Duramax 6600
    Last Post: 01-25-2003, 06:00
