Originally Posted by
AugustDiesel
Supposedly this is an NA 6.5L Goodwrench engine, my guess is an earlier one as it has the v-belt system. Thoughts?
The belt system is dependent on the year of the vehicle the engine is in, and not the year of the engine. For instance, the 1982-1987 square body style trucks will all have V-belts from the factory, regardless if the engine has been replaced. Normally, if a 6.2L is replaced with a 6.5L, all of the original accessories and belt drive system will be swapped over to the new engine.
