Originally Posted by
ulhpilot
Also, when troubleshooting my '92 from now on, will I have to act like it's actually a later ('97-) model since it's now got all the later hardware? I looked at the '97 cooling circuit and it looks like it doesn't have the same temp sensors.
Mick
No, since your 1992 has a mechanical fuel injection pump, and the 1994 and later models have electronic injection. Completely different animals with different wiring. The only thing that has changed on your upgrade is the physical location of the throttle cable, and possibly the high idle solenoid, due to the new location of the outlet on the thermostat housing.
